Clayton Wetter
I know that a few years back you were big on going to google earth and finding out the actual size of some of the speedways.
I always felt as though Eldora speedway and Toledo speedway were the same size.
Could you check out these 2 speedways and find out how close they are in actual size.
The reason I want to know is that I see that a winged sprint car time trialed at 12.14 at Toledo and I am pretty sure that the Track record at Eldora is around 12.79
im not clayton but had some time so i fired up google earth... toledo measures .43 around the inside and .49 on the outside wall eldora measured at .39 on the inside and .48 on the outside
Thank you for coming up with this information. It looks like Toledo is just a little bit larger overall and both of these tracks are SMALLER then a half mile...
Not many true half mile dirt tracks left that are used for auto racing. Terre Haute and The Belleville High Banks are a couple of the last in the Midwest.
Williams Grove, Selinsgrove, Port Royal, Bedford and PPMS are all true half miles still running in PA.
Guerrilla Racing Junkies!
Rome, in GA, is a true half mile, and claims to be the fastest.
Originally Posted by Black I
Hartford (still in operation) claims a half mile.
Not anymore I don't think. They downsized it some.
PA isn't in the Midwest. It's in the Northeast
He didn't say in the Midwest, he said there weren't that many half miles left in operation in general. I was just mentioning some of the half miles out this way.
My post was in reference to your post after you quoted Cirf which he mentioned Midwest.
West Liberty Ia and Davenport Ia are half mile tracks and may even be bigger.Any one Know for sure?
My measurement of Eldora around the outside wall is 2680 ft. Which is 40 feet over a half mile right on the wall itself. Of course the cars run a bit shorter distance. I consider Eldora as a true half miler.
I just measured Toledo at 2630 FT. around the outside wall.
These are what I have come up with. I thought Toledo might be bigger but I did measure it twice.
I always thought Davenport was larger than the 1/2 mile advertised. Just seems big.
8/13/16
BTW my measurements on ROME are 1980 FT. On the outside wall.
I was told Davenport was a half mile on the bottom. West Liberrty took the same gear as Davenport, back in the day. Iowa also has Oskalosa a half mile Knoxville, Eldon, 34 raceway and Donnelson are short half miles I believe there are a couple in the north west part of Iowa too. DesMoines Fairgrounds got put to pasture.
These what I have come up with. I thought Toledo might be bigger but I did measure it twice.
Check out the measurement of the inside wall of both, that way we can average what it is in the middle of each track. Can not be considered a true half mile if the cars can travel a shorter distance. Everytime I see time trials at Eldora the cars are in the middle of the track in the turns...
I don't know where the cars run at Toledo but at Eldora they are usually real close to the outside wall and also they don't run near the inside of the track.
This is a good discussion we are having here and I have to agree with you about the cars running at the top of the speedway at Eldora. However they are doing this when the track is slower and the top of the track is the quickest way to go then.
So what I did was go to you tube and type in the track record for late models at Eldora and BINGO there it was. It was set on Sept. 12th 2015 and it showed the two qualifying laps by Chris fergesen (excuse the spelling) You can clearly see that he was in the middle of the turns not the top so he did not cover a full half mile in distance. So there you have it. Video is clear proof of where the quickest speed is at Eldora...
Right or wrong, You still Da Man and if you should run for president of the 4M forum, You got my vote...
So what I did was go to you tube and type in the track record for late models at Eldora and BINGO there it was. It was set on Sept. 12th 2015 and it showed the two qualifying laps by Chris fergesen (excuse the spelling) You can clearly see that he was in the middle of the turns not the top so he did not cover a full half mile in distance. So there you have it. Video is clear proof of where the quickest speed is at Eldora....
Even when measured on the extreme high side of the track right next to the outside wall Eldora isn't a legitimate 1/2 mile. It lacks at least a couple of hundred feet of being a true 1/2 mile. And when measured in the middle of the track where you say the late model track record was set it's even substantially shorter.
Do they run high at Toledo? I have never been there.
You are right about Fergusen's lap. Usually they run higher as the cushion moves up sooner than when Fergusen did his lap. Best I remember the track was wetter than usual from a rain.
Looks like the track is about ten feet wider at Eldora than Toledo on average.
