Qualifying uderway
Overton crashes in qualifying may need backup car
I thought you had to race the car you entered. No backups
That's the way it used to be but that was under the old format so I don't know what the rule is now.
Not sure guys went to backups last nigh..but they fixing the primary car anyway..JD fast time through 45 cars
Moran eats wall in qualifying. .
Overton car is fine
JD 4/10ths off track record!
Originally Posted by Illtsate32 Moran eats wall in qualifying. . Fukin Devin...
Thought JD was washed up?
Member of the Luxemburg Speedway Hall of Fame Class of 2019
Eldoras live timing is screwed up tho
Bloomer clocks in 12th for now
Tracks slowing a bit got some bumps into 3
The guy that spun in front of McDowell last night barrels into 3 a backs it into wall a ton...on warm up lap
JD fast time..Lanigan Sheppard Hickman Marler top 5 qualifying complete
Cornett power baby!
Originally Posted by chupp n bloomer fan Fukin Devin... Wash your mouth out with soap boy!
Lightly raining now. It should clear in 20 minutes or so.
Originally Posted by Shiny Side Up 18 Lightly raining now. It should clear in 20 minutes or so. Can't be having a little bit of water on the track now...🙄🙄🙄
The 50/50 is over $18,000.....on Friday.......before the heats have even started.
