Results 1 to 8 of 8
Thread: gears 4 gateway
    Question gears 4 gateway
    gears 4 late model and modified at gateway dirt
    Nov 2014
    488
    I was on a 7.12 with a 358 flat tappet nlms motor with spec brodix aluminum 23* heads. Turned 85-8700.
    Granite City, IL
    89
    I ran a 6.86 in a mod. I had a good full roller 355, turned it 8200
    Feb 2016
    The land of Irma
    3,774
    Quote Originally Posted by brewster baker View Post
    I thought your Six Pack crew "acquired" whatever parts you needed!
    Turn LEFT, Vote RIGHT!
    Nov 2012
    Wisconsin
    3,119
    I wanna know Lonnie Anderson's bra size..
    Class of 2019
    thanks 4 the answers it is hard to acquire parts with all them in closed trailers
    1,903
    The flat tappet turning 8700 sounds like a great idea. I know the cup guys used to use the cams with the hard face overlay welded in and some super expensive lifters to pull that off. Do 23 degree heads even make power at 8700 ??
    Nov 2014
    488
    It was only a split second I figured. I wanted it to launch off the corners so I hung a gear in it.
