Stacker trailer question
I know this isn't late model related, but figured this is one of the most looked at threads.
Just purchased a 46' united stacker. I've never had a stacker before. So I've got a few questions. Some of these questions are probably dumb but I've just never been around one.
1. Is the 4 post lift suppose to be 100% solid or do they normally sway side to side a little bit. This one moves some and you can tell where it's rubbed on the side walls of the trailer.
2. The posts have big brackets 3/4 the way up, but are not mounted to the sidewall of the trailer. Was told you can not attach the lift to the side walls. I'm guessing this is true?
3. Any special instructions for hauling a car on the lift?
4. Basically anything else I should know?
Thanks
