Results 1 to 7 of 7
Thread: ball joint
    Jul 2017
    11
    Default ball joint
    can someone give me a howe lower ball joint pn. for a pinto spindle on a pierce car.
    Feb 2016
    The land of Irma
    3,774
    Unless something has changed, you have to get it direct from Bob.
    Turn LEFT, Vote RIGHT!
    2,814
    That's correct only from pierce
    Sep 2009
    831
    What the hell is so special only BP has them? Are they making their own parts or something?
    Nov 2007
    509
    Is it screw in or press in.With howe bj you can put Chrysler studs in chevy housing.I have a bunch of howe stuff, measure your stud and post it
    Sep 2009
    831
    Same with QA1
    You can put any stud to any housing as long as the ball is the same size. Id venture a guess QA1 knows what BP is using and has an answer for much less.
    Nov 2007
    509
    Howe bj are around $80 and the stud only is $30.IF Pierce is in that price range It would be easier to get on the phone.I use the same housing and change studs.Been awhile since I bought one, but a moog 727 is around $40 locally
