Results 1 to 4 of 4
Thread: RR Tire Rub
    Oct 2007
    205
    Default RR Tire Rub
    I have a 04 GRT set to GRT sheet. The RR is rubbing the upper frame rail. It is just barely starting to lift the LF. Would it be ok to move the rear to the right just a little or maybe stiffer spring in RR. What would be effects of the changes. Lr is 250, RR is 225.
    Batavia, OH
    13,634
    Quote Originally Posted by ace1 View Post
    I would get the 1/4" wheel spacer plate from one of the manufacturers and roll with it.
    Atomic - 1
    Dec 2014
    pa
    218
    ace, my 05 was set to grt specs and tire rubbed the frame a bit also, the car was also moody, talked to them about it , jbar was set at 19.1/4 like it says, turns out theres a measurement 16.1/4 center of driveshaft to inside of 2x2 for the jbar mount
    Oct 2007
    205
    I think I'm at 16 on the center of driveshaft to 2x2 mount. I will check that.
