Sell out
‼️ FOR SALE ‼️
1999 38ft Pace America tri-axle race trailer. Large tool box, 3500lbs winch, air compressor plumbed to front with hose reel. Black in color, pulls well with no leaks tires are 85%. 8,500$ (bill of sale only)
Complete Weeds Motorsports NeSmith 604 crate. Motor is complete fan to tail shaft. Single blade fan, KRC serpentine system, edelbrock water pump, water hose plumbed from front to back of intake, HVH 5/8 carb spacer, pro cam fuel pump, MSD distributor with Jay (not a nice word)(not a nice word)(not a nice word)(not a nice word)ens wires, motor has less than 350 laps on it. Always less than 200 degrees always ran on Schaffers 20w50 with wix filters changed every 4 nights. Shaw motor plate. Bert reverse mount flywheel. Sweet reverse mount P/S pump. Bert Starter. Bert Bell-housing. Bert Transmission. All really nice stuff that’s been taken care of would like to sell complete 8,500$ buys it all.
1- Willy’s Gas carb 650$ ready to bolt on
1- Willy’s E85 carb (needs freshened) 500$
1- Stealth gas carb (needs freshened) 500$
1- Complete Frankland lightweight rear end with low drag bearings and seals. Completel hub to hub with winters hubs and rotors, GM calipers, BSB birdcages, BSB Beale floater, 4 bar rods with spacers, chain mounts, Shaw pull bar brackets, X- Factor pull bar with blue/red bushing, BSB pinion plate, Shaw j-bar, fast shafts Steel driveshaft and rear end fill tank 2,000$ ready to bolt in and go.
1- Complete set of Integra Schrader valve shocks gone through by Shaw 3 races ago (RF, RR, LF, LR)
Will come with a TSM top shock and BSB slider to make a compete set ready to bolt on and go 1,400$
12- Mod wheels and tires (4) Beadlocks (8) non bead locks. 40$ for non 60$ for Beadlocks
2- Speedway 3 piece spindles with hubs pads and calipers 125$ each (6nights on them)
2- Pinto spindles with hubs 75$ each
1- Sweet front mount P/S pump with mount 100$
2- GRT tubular lowers complete with QA1 Balljoints 125$ each
1- Battery box 20$
2- weight jacks 30$
1- Optima Battery with master disconnect 100$
1- set of Simpson 2” Hans style belts dated 2015 75$
1- Complete MSD setup box, coil, solenoid 150$
1- Coleman bearing Gas pedal 50$
1- Wilwood reverse mount pedals with mc’s 120$
1- Oval craft P/S tank with lines 50$
1- 2-1 steering quickner 30$
1- 605 box with steering arm 150$ no leaks
1- Bert reverse mount starter 75$
1- Complete fuel line set with filter and all fittings 50$
1- 22x20 FSR single pass radiator 100$
1- set of Schoenfeld headers for mod (6 races) 100$
1- set of Schoenfeld long tube crate headers with anti-reversion mufflers 300$ fit TrakStar late model and several others.
1- right side Beyea crate header with muffler 100$ fits trakstar and several others.
1- GM 604 crate intake 75$
1- MSD with Mallory cap and Taylor wires 125$
1- Mod driveshaft new no yoke 100$
1- Integra Stealth series schrader valve shock (shaft is bent) 100$
1- Fox Rf bulb top shock 200$
1- Fox Lf non bulb shock 130$
1- BSB Black front mod shock 50$ looks rough but still functional
1- Butlerbuilt 14.5 EZ sprint seat powder coated black 300$
1- Ultrashield regular 20* layback seat with Kirky bolt on full containment head and shoulder pads 175$ (most comfortable seat I’ve had)
1- GM 604 Crate block bare. I️ know nothing about it as is 250$
1- GM 2 bolt main block as is 100$
1- GM 4 bolt block as is 150$
I️ couldn’t tell you the first thing about the any of these blocks come look for yourself.
1- Steel block Steel Head Mod motor. Iron eagle heads GM block. No idea on the internals. Needs freshened 1,500$
1-Race Lift pit lift 1,500$ will not sell until everything car related has sold.
Several blocks of lead ready to bolt on 1$ a pound.
Ball joints, pitman arms, idler arms,drag links several of each make an offer.
Several sets of quick change gears various ratios 40$ for standard 60$ for SCS lightweight gears
Several Mod and Late Model springs various weights 20$ spring.
Several older Late model wheels and tires not pretty but would get you by in a pinch 50$
All prices are OBO call or text me I’m all but certain we can make a deal.
NO TRADES
Chad Williams 1-870-897-7732
