Blue front
in your opinion whats the best ball joint and controll arms setup for a blue front rocket?
Your not going to get a good answer, that kind of info is held tight to the chest.
Joes and Howe....imo
We did use the std Twms for a while though!
Turn LEFT, Vote RIGHT!
Howe balljoints for sure, upper control arms- Joes, Howe, Twm, or port city/keyser are all good choices .
What brand balls joints is " held tight to the vest " ?? I'm pretty sure looking at a car for 2 seconds could answer that question.
I big percentage are on Howe and Joes stuff. Alot of builders make their own arms now too so they can customize them Like Heim ends at the cross shaft etc. You cant go wrong with Howe or Joes, or Keyser, I run some Lefthander stuff on my asphalt car, I like that Howe uses the same keyways for their slotted arms and they a arm plates where Joes does not. But I have a little bit of them all and have never had a problem with them even used some Lazer stuff they are great as well and carry alot
Lengths, spindles etc,...................... Brands, C"MON man!
