Results 1 to 4 of 4
    1,008
    Default another trans question.
    hi, I'm in the process of building a street stock and I need some input on what transmission I should use. we can run any automatic or manual trans setup, factory or aftermarket. all I have now is a flexplate and pedal assembly from when the car had a powerglide in it. this will be on a 1/4 mile dirt track, 383, 3000lb car. thanks.
    olin
    Sep 2012
    127
    If you can run a bert or brinn I'd go that route
    Dec 2008
    1,238
    Jul 2007
    3,224
    tongonietranny is junk. I owned 3 at one time and was dealing with replacing them non stop, the shift mechanism he is rigging is sub bar at minimum. I put in a new one at the track that was my spare and it didnt work properly.
    avoid avoid avoid
