Thanks for all your info! Do you have a good starting point for setting up a stock car?
900/800
275/275
no lead behind axle
if you have a lot of lead mount it low as near the transmission as possible in ONE pile
If not a lot 100 or less shoulder height behind seat is good
I liked 200 cross, 50 rear max, left my shop at 48 always low on fuel ready for heat
I quit racing and dont want to get into a lot of tech. I just check in once in a while since this forum is all but dead in the tech and there are some non racers replying more than anything.
One more question the car had a 10 gallon fuel cell in it when I bought it would it be advantageous to put a 22 gallon cell in?
No I ran a 12. you want the least amount of weight possible in the rear.
and you want to run the least amount of fuel possible.
if a 8 will finish all your features then run a 8
I ran a 12, filled it to 8-10 gallon level for the feature and ran what was left the next week for the heat races. that was my method. If I put 12 in for a real dry feature I sucked some out for the next weeks heat
