Dry sump
Anyone use the blue push on hose for dry sump setup? From pump to filter to cooler to engine. Got hose and fittings just curious if it was a good idea. Hose is rated for 250psi.
I've seen it done, can't say is recommend it but it does work. I have ran it for oil pressure gauge with zero problems. I would say to be sure to use the clamps and only use it on pressure side as it can suck closed on vacuum side.
