Results 1 to 6 of 6
Thread: Bert shifter
    Brookfield,WI
    116
    Default Bert shifter
    New to Bert trans. Older Bert. Looking at the trans where shift linkage connects, which is high/low and which is reverse the top or bottom? Using the shifters I can get both to move forward independently which pulls shifters out of trans, but cannot get either to go back? Does car have to be moving? Hopefully making myself clear. Any help is appreciated.
    Sep 2009
    831
    Top is LOW/HIGH
    Bottom is reverse.
    One shaft has to be in neutral before the other will move.
    Jun 2007
    3,123
    Quote Originally Posted by shawburn View Post
    Bottom is R/N. Out is R. Nut lined up with housing is N
    Top is H/N/L. Out is L. Nut lined up with housing is N, Nut inside housing is H.
    Brookfield,WI
    116
    Thanks that is what I was looking for. Was not sure if nut goes into housing. Thanks.
    Nov 2012
    Wisconsin
    3,119
    The big nut goes behind the steering wheel...
    Class of 2019
    Brookfield,WI
    116
    And in my case it is!!!
