Results 1 to 4 of 4
    Aug 2007
    388
    Default Rocket ride heights
    I know this probably has been asked but didn’t find the exact answer I was looking for.
    02 black front Rocket with double box crossmember, car does not have a raised RF rail. I know the measurements are 3 5/8 & 3 7/8 per the 08 setup manual. I changed to the 1pc lowers with screw in ball joints and it appears that the spindle sits higher than with the old 2pc setup. Are the ride heights still the same between the top of the lower and the bottom of the frame rail?
    1,396
    Memory serves me right, yes that's still same
    Aug 2007
    388
    Ok thank you.
    1,396
    If helps any I spoke with rocket some time ago regarding an 03 and I was told then that rear suspension points hadn't moved since went from wide rear. The black car fronts were the same till went blue (??). That's from rocket and when everyone started seeing the huge camber gains on rf and chub was on like a 150 rf. Lots has changed and best advice I can give is call rocket & ask for Anthony. Awesome dude who will explain in terms you'll understand!
