Can't you calculate your extended load by how much the spring is compressed?
Punisher88
Yes, just measure springs compressed length on the car with rear end hanging. Then calc the rough pressure by subtracting that from the free hieght of the spring times the rate
Example: extended measurement of spring is 12.75" and it's a 14" spring so 1.25 x rate = extended load # or least a rough estimate.
Try taking the heavy cage off. I had a similar problem. Car was bad fast when track had any kind of moisture in it and then when it went slick you’d drop ancor. Took the heavy cage off and left everything the same and was instantly better.
