Results 1 to 5 of 5
Thread: Swing Arm!
    May 2009
    1,336
    Default Swing Arm!
    Tuning on a 3 link Swing arm shocks on Trailing arms with a pullbar and short J bar. Camaro Clip front. 54% Left 54% Rear 245 Bite on a 900 LF 1000 RF 350 LR 325 RR Struggling with drive off and tight in. Short Bar 2" Rake Top hole on Pinion. Suggestions. I have a decent understanding of a swing arm but setup seems to vary alot
    May 2008
    574
    Bite should be close. Front springs look heavy. How much travel are you getting in the front ?
    Pull bar to the left side of the rearend and the chassis ?
    Be sure that the short bar is not limiting body roll. Try even with pinion and less angle in it.
    I never had any luck with the shocks mounted to the trailing arms. Always ran them on the birdcage behind. Only ran a swingarm car for about 3 months so I don't have a lot of experience with them.
    1,397
    Depending on tire I'm thinking you need more rear percentage
    Aug 2016
    212
    Add stagger and wedge.
    Jan 2014
    245
    Default Swing arm
    7up pm meNote the swingarm spring
