Results 1 to 7 of 7
Thread: Carb question
    Dec 2007
    643
    Default Carb question
    putting a 750 on a 604 can anyone give me a starting point on what jetting i should use?
    May 2008
    574
    Nobody else?
    My answer is still the same as last time.
    #73 jets all around with a 4.5 power valve.
    If you have any doubts, put a fresh set of plugs in it, hot lap the car and do a plug reading.
    Jun 2010
    Santa Land
    554
    Gas or alcohol?
    Dec 2007
    643
    its gasoline
    Jun 2007
    1,047
    Not all 750 carbs are built the same so jet size can be different from one to another. The fuel properties also affect jet size. Nobody can accurately answer the question without more info so be careful.
    Oct 2007
    974
    very well said 50j
    jet question is a daily phone call here and they all get the answer that you just provided
    questions to ask--
    what fuel?
    what style and size booster?
    what size orifice behind the power valve?
    what size air bleeds?
    what arrangement is the emulsion pack?
    normal altitude ranges?
    plug in these numbers and we can get close on jetting
    Brad
    www.race-1.com
    Dec 2008
    thedirtysouth
    4,014
    start with the 72.s it probably came with and do what was suggested above , learn to read the plugs.......
