Results 1 to 2 of 2
    Default Lightning Chassis roller $4900
    UMP Dirt modified Lightning Chassis 2009 Chevelle clip totally refurbished like new last season. $4900 3rd in points at the fast Volusia Speedway track last year. Consistently finishes 3rd to 6th with little 377 flat tappet cam engine. Put your big roller cam engine in for wins!!! You won't find a fresher used modified on the market. We took engine/transmission and seat/belts out. All else goes with car. If you have an older or worn out mod you can upgrade inexpensively by taking your drive train out and drop it in this car and go fast. Only 20 races on car since taken down to bare frame, sandblasted and painted frame, built back up with lots of new parts. New Winters quick change put in too. Over $3000 spent on new rear and rebuilding and revalving shocks alone last year. Only selling because we have a new 2018 Lightning chassis we are assembling to replace it.
    Frame stripped bare and sandblasted and painted first of last season. About 20 races since then.
    Radiator
    Dash gauges switches and all wiring replaced
    Brake bias gauge
    Battery
    Shifter
    the good Bilstein gas filled rechargeable shocks all 4 corners
    2 to 1 steering quickener
    22 gallon fuel cell
    steering box, steering shaft with quick release hub and steering wheel
    Chrome Aero wheels
    New Winters quick change rear installed
    Pull Bar
    Drive shaft
    All spec and setup sheets included and support after the purchase. Car was 3rd in points at Volusia in 2017.
    Will deliver for cost of gas for truck to travel up to 1000 miles. Free delivery up to 300 miles. Meet you half way to save you some costs. Will put new sides on car for price of aluminum panels.
    $4900 http://www.garygrossracing.com
    still available...... Our new Lightning car is about fully assembled and need the garage space so come get it. Don't spend a bunch of money on someone's worn out used car then spend thousands more to make it competitive. We already spent that money on this one. Everything from bare frame new or freshened up on this one and a great track record since freshened!!!!!!
