camber loss
hi guys, I had a guy tell me that I was loosing all the camber on the rf during compression at mid corner. So I took the spring and shock out put the camber gauge on it and ran it through its travel. With wheel straight started with 5 camber at full travel (3 1/2 inches) it gained 4 degrees. I turned the wheel 20 degrees to right , it lost 2 degrees camber and at full travel it had 0 camber. The arm is mounted parallel with chassi center and it is 7 1/4 long. Just wondering if I should be concerned and if so how to correct it. Oh its a stock metric frame and all mount must remain stock and stock location.
Thanks John
