Results 1 to 7 of 7
Thread: Oil restrictors
    Sep 2012
    brown city Michigan
    161
    Default Oil restrictors
    Any one have a problem with the mains not getting enough oil and destroying the bearings when using oil restrictors
    May 2008
    574
    If you are talking about the screw in restrictors for the lifter galley in a SBC, no, I have never had any problems with them. They are used to restrict oil to the lifters, pushrods and rockers and to keep more oil on the mains and rods.
    Aug 2014
    106
    I have ran them on roller motors to cut the flow to the valvetrain. I only wish I hadn't used them on my non-roller, flat tappet solid cam, "stock rocker", engine. It cost me a set of pretty expensive lifters and rockers. All from lack of oil.
    Jul 2007
    3,224
    they come with different hole sizes, you probably got some for a roller cam not flat tappet.
    Sep 2012
    brown city Michigan
    161
    I am running a roller cam. Never had a problem before but didn't use oil restrictors. Thinking I'm just going to put the factory plugs back in it and try that. Also it's a mowtown block
    Jul 2007
    3,224
    restrictors restrict oil to the top end not the bottom
    they did not and can not cause you to have a issue with your crank or rod brgs
    I misread your original post.
    Sep 2012
    brown city Michigan
    161
    Ok.. thhanks. I think it's something the machine shop did cuz now they want me to take my block back to them for when ever reason when they had all my parts before when they said they line bored it
