Owens wrecking everyone
He takes out Zack Dohm then Tyler Bare. Class act he is for sure. Maybe the Tyler. Bare issue could be called a racing deal but he drove into the side of Dohm
Maybe it was for something that happen early.
Where did this all happen at and when ?
video is on the WoO twitter page
World Finals videos on Twitter
Dohm didn’t really give Jimmy any room either when he is clearly up beside him
https://twitter.com/woolatemodels/st...624188422?s=21
3 cars in a lane for 2 wide at best. Something had to give.
https://twitter.com/woolatemodels/st...499441153?s=21
"everyone" all 70some other cars .... "everyone"
The Stranger: Somebody left the door open and the wrong dogs came home.
Looked like a racing deal to me. Maybe a bit on Dohm.
Did I hear that Jimmy Owens was off the Lucas Oil tour in 2019
I always thought Owens was Mister Clean and showed other racers a lot of respect. Must have been unavoidable incidents.
Lmao
Wrecking everyone?
Both racing deals. Tyler Bare one Max was in the lead and Tyler tucked up under him. Just as Tyler changed lanes, Jimmy was committed to the bottom and had a run. You can see him try and get out of the situation, just too late. Racing deal
Zach Dohm one he is beside Zach, and Zach doesn’t budge, also a racing deal. He didn’t mean to take out either one, you can see that in the video.
If your telling me Jimmy didn't drive into turn 1 to hard u don't get it.
Owens didn't do that on purpose.. I know it's end of season and Zach had his car probably destroyed but racing deal IMO
Think the zack deal hard racing running pretty much same line on the hub. Zack cut hard run his nose around the hub to cut jimmy off. Jimmy had to cut hard under zack losing lot speed checking up making his ass slide out under him losing traction, Then no air played in hand. Yeah you could say jimmy drove over his head if you didn’t look at all the factors played in hand running for same real state.
The Tyler deal most on Tyler. He cut from outside line to split jimmy who was married to the hub and max Running low mid line. That was Tyler bad call trying spilt jimmy and max.
Doesn’t matter whose at fault between Owens and Dohm, what matters is the fact that after contact was made Jimmy stayed in the gas and turned right causing zack to flip. He never would have gotten turned over and junked his racecar if Owens would have just hit the brakes and stayed off of him. Completely classless and bonehead move.
No one is going to want to hear this but Owens and Dohm were battling hard for a transfer position on a very fast track , Owens was there on the inside , Dohm probably didn’t know he was there but he was there and Dohm yanked it left 90 degrees like no one was there . With Owens committed for the corner already if he jumps off the gas and slams on the brakes his car snaps around instantly and either backs into the wall or gets drilled by oncoming traffic. The only thing you can do there is stay in the throttle and counter steer , that’s what gives you the least chance of junking your car. Once they got to
Mid track he could have backed out slightly and gave Dohm more of a chance to save it. Owens didn’t over drive the corner and slide up and plow Dohm like people are insinuating. Dohm cut across his nose and Owens didn’t slam on the brakes and let him. If you have never been in the situation Owens was there you don’t understand how quick that happens and how fast you have to react to try saving it. Yes it’s a shame Dohm got his rear clip ripped off as a result but had he left Owens 8ft on the bottom there wouldn’t have been a wreck. How does Owens know Dohm is going to yank his car 90 degrees left across his hood ? Exactly he doesn’t and he had a millisecond to
React when he did . In that situation if you are Dohm you can expect Owens to lift but you can also expect to be disappointed because the majority of the time in that exact situation the inside guy is not going to lift especially racing that hard on a fast track when there is 76 cars and they are taking 22 plus provisionals which Owens did not have
Took him out? Racing deal. Man up or go cry somewhere else sick of whiners
Give me your address I’ll send you a cookie so you feel better
