Results 1 to 3 of 3
Thread: Shock opinions
    Aug 2014
    106
    Default Shock opinions
    Running a 3200lb metric car on a 3/8's moderate to high banked dirt oval. I last ran RF 1100lb LF 950lb RR 250lb and LR 225lb. I have different spring rates to try. Shocks were RF 6 valve LF 5 valve RR 4 valve and LR 5/3 valve. I also have a few different shocks to play with. Car is set up for all 9" shocks, currently have oil shocks. Thinking of running Bilstein gas shocks.Thoughts??
    Aug 2014
    106
    With all of the knowledge here, still no suggestions???
    Jul 2007
    3,224
    search my name see if enough of my posts are still visible to help you.
    I assume your racing and not talking about a dump truck, but your front spring rates seem like a dump truck
    If you want to start conservative
    900 800
    275 250
    5050 8040 80 rebound 60 compression
    3030 3030
    8040 rf would be a adj for drier track you could put this on the LF on a really really heavy track to free the car up a little also
    I NEVER ran splits on the rear in the last 5 years I ran a stock car which are when I won most of my races.
