Results 1 to 8 of 8
Thread: Rod End Lube
    Default Rod End Lube
    What does everyone use to keep rod ends/ heim joints lubed? I've used the white lithium spray grease, wd40, air filter oil, or whatever I had in the trailer but never really put much thought into it. Are there pros and cons of using different stuff? I usually do it every week after washing the car so the joints are clean when applied. Shocks/j-bar/trailing arms/lift arms/steering arms/etc.
    1,396
    I get spray at Napa like $13/can. Can't think of name but it's graphite stuff and stays applied even when gets wet
    Kansas
    1,940
    I think Jim is thinking of dry graphite spray. I like it as it's not wet and doesn't allow dirt to stick to it and act like sand and wear out rod end faster.
    Dec 2008
    thedirtysouth
    4,014
    shaffer makes a lube called pentro 90 that is the best i ever used ,
    Aug 2018
    5,233
    As an ole go karter I always preferred Tri-Flow. Plus, if you spray it in your eyes, it doesn't burn!
    Speaking from non-experience of course!... wink!
    Batavia, OH
    13,635
    Be careful with petroleum if you have heims with teflon.
    Atomic - 1
    in a van down by the river
    1,892
    Default lube
    Quote Originally Posted by MasterSbilt_Racer View Post
    yes should not have to lube Teflon heims at all. just make sure they are clean.
    Jan 2014
    177
    Gibbs/Driven speed lube specifically formulated for moving race parts.
Tags for this Thread
