Rear end ?
So, just doing some random thinking, with late models and mods all doing the heavy left rear
thing, do you think there would be a benefit to weighting the lr axle on a stock car? Always wondered
if this would work with the stock style rear suspension.
Curt Drake
#55x
sure, your turning left
just put some water in your left rear tire
ha , have you ever tried that SCD ? cause i saw some one try that on an old bomber one time , at speed that thing was having a fit....
Race tech constantly moves down from the higher classes to the lower classes. A heavy left rear should make a car loose of the throttle, and also it should make a car tighter on the gas. This is assuming that the cars rear suspension has adequate rear suspension to allow the left rear to drop enough when needed. In a stock body class using stop type metric suspension, you need to do things to help the suspension travel more like a Late Model would. This would include doing things to allow freedom of movement in the rear suspension. The NeSmith stock cars have been doing non conventional things for a long time, like rear control arms with non stock suspension swivels that allow a greater range of motion.
Also, be aware that when you allow the left rear to drop like a late model would, you will probably have too soften the rf spring rate, and you will also end up needing shocks that will tie the rf down, and u will most likely benefit from a lr holdup shock. Remember, that when the left rear drops, the rf most go down, or your car will build a tremendous amount of dynamic wedge, and this will make the car really, really tight when on the throttle, and if the rf bottoms out on throttle application, the car will push up the track at the moment when the rf bottoms out. This is why many cars are running on bump stops, and figuring out the correct rf spring rate/bump stop setting is largely a matter of experimentation. This setup is very common in all classes these days. Many of the late model guys are buying super expensive chassis these days, and they are paying the money mostly to get setup help from high level setup men. For a team with a limited budget, there is no replacement for somebody who can watch the car go around the track and give feedback. I have seen 10+ year old late model chassis run very competitively simply because they had some one on the team who truly understood what the car needed.
It wasnt full enough then... It needs to be to the top of the rim at a minimum.
You might get that to work with a very full radial tire. Bias ply, no way.
i dont know what was on that bomber but by the flag stand , the whole rear end was hopping of the ground .....
