Results 1 to 7 of 7
    Jan 2011
    Hoffman, MN
    46
    Default 2015 Black diamond ball joint
    Could someone tell me the Howe ball joint number for a 2015 Black diamond right front lower?
    Thanks much
    Nov 2012
    Wisconsin
    3,119
    Do they use a screw in or uniball?
    Class of 2019
    Jan 2011
    Hoffman, MN
    46
    They use a screw in
    Kansas
    1,940
    Quote Originally Posted by tornadochaser7 View Post
    They use a screw in
    Should be 22430, which is a screw in with the Chevy taper on stud. I don't know if they use a longer or shorter Chevy pin or not but that is the std length one.
    Add an S on the end if you want a steel cap over the std aluminum one.
    To change pin length:
    -.3" 2243103
    -.2" 2243102
    -.1" 2243101
    0 22430
    +.1" 22431
    +.2" 22432
    +.3" 22433
    +.4" 22434
    +.5" 22435
    +1.0" 224310
    Our 17 uses a 1/2 longer lower ball joint on the rf. I would just call BD to confirm they will tell you.
    Jul 2014
    399
    A 17 has different spindles than a 15 IIRC...(correct?), agree, call BD.
    Apr 2014
    294
    Did Stucky give you a part number?
