Looking for some opinions
I crashed my metric Monte bending the front clip right behind the cross member.Would I be better off cutting the entire cage loose and building another car or just clipping the existing chassis?The way it is bent I highly doubt being able to pull the chassis straight on a frame machine
first option would be to try and pull it on a frame machine. take it to someone that does LOTS of race cars. Ive seen "totaled" cars fixed in an hour or 2.
If it cant be pulled, then I would replace the front clip. carefully cut it apart at the factory seam at the side frame rails. Most of the time you can take your time and save most of the bars.
