Results 1 to 4 of 4
    Jun 2007
    Pennsylvania
    105
    Question Driveshaft question
    We are piecing together a 1981 Malibu Hobby Stock that came without a driveshaft. What length one will I need with the engine in stock location using the 7.5" rear with a Powerglide transmission? Need to know in case I stumble across one that will work before we get to that point in the mocking up step and can do an actual measurement. Thanks in advance!
    should be 52 1/2"
    Jun 2007
    Pennsylvania
    105
    Thanks oilman!
    in a van down by the river
    1,892
    need to upgrade the rear end. I don't believe those 7.5 axles are not strong enough for oval track racing.
    JMO
    if you try it, make sure you do the c-clip eliminators on the axles . that is the weakest point
