Results 1 to 6 of 6
    Mar 2018
    Macon GA
    218
    Default Bert Gen 2 oil blow by?
    Just recently I started noticing a bunch of oil around the transmission after runs and idling in the shop today, it pushed a decent amount of oil out of the over flow tube on to the shop floor. Any ideas? Hasn’t done this before and it’s relatively fresh. Thanks
    in a van down by the river
    1,892
    how much fluid are you using to fill?
    IIRC it is like 3/4 of a quart.
    also do you have the vent tube running vertical, then a loop at the top and running back down?
    Mar 2018
    Macon GA
    218
    Quote Originally Posted by JustAddDirt View Post
    how much fluid are you using to fill?IIRC it is like 3/4 of a quart.also do you have the vent tube running vertical, then a loop at the top and running back down?
    I have a loop, and it filled to the bottom sight glass
    Mar 2018
    Macon GA
    218
    1,892
    needs to be 1/2" below fill plug or site glass.
    believe you have to much fluid in it.
    Jul 2014
    399
    Thumbs up
    needs to be 1/2" below fill plug or site glass. believe you have to much fluid in it.
    VERY probable and likely This^^
