Results 1 to 3 of 3
    796
    Default Dry Sump Tank Smoke
    Anyone ever had smoke come out of their Dry Sump Tank breather? It's like a light wispy smoke. I've never seen this before. Want to make sure it's nothing bad.
    Aug 2012
    212
    Condensation from inside the engine. Let everything get up to temp and it should quit. Happens if you crank it up and shut it off a couple of times without getting temp high enough to evaporate any moisture in the crankcase. Happens more in high humidity areas. Make sure to seal everything good when you wash the car. If it doesn't quit it's a bigger problem.
    796
    Ah thats it. It's been very humid and cool here lately and it's been a week since I had the car running.
