Help with 2004 Pierce Clamp
Having problems with setting the rear end from side to side. I recently bent the rear clip to the right, exactly where the shocks mount. I realized it when I went to set the left rear shock at 15 degrees and the RR was inline with the RF. I was planning on centering the rear end and just moving the upper shock mounts. What’s the best way to center the rear without using the shock angles? And what should the RR shock angle be when the LR shock is set at 15 degree on a spring infront clamped up? Thanks
Pierce
Line up left side wheels with 2in offsets
Originally Posted by
anissa5
Thank you!
^^^ yep! Line up left side and get your new measurements.
Tags for this Thread
