Results 1 to 8 of 8
    2,931
    Default Pull Bar Spring, Pre-load and Location?
    900 to 1200 Hyperco, how much pre-load is typical?
    Also, i changed the QC Plates to Wehrs models, the stock one had no movement available. Anyway, what does 1" ahead of axle, and 1" behind do for ya?
    Pierce Platinum, UMP tires. Generally tight in, and lose off. Been messing with droop load, and RF spring to no avail. Pulled the pull bar out and found it was pre-loaded a lot, and was mounted biased towards the LR tire, a lot LOL.
    Centered it, and now wondering about the mounting, also have a 3" behind CL option to mount to now.
    Been a few years out of the Mod game, so thanks for any help.
    Just say no...
    in a van down by the river
    1,892
    front of axle CL gains angle, and continues to pull into spring on wrap up
    behind CL loses angle and rolls out of spring on wrap up.
    first thing i would do is soften LF spring.
    or take out a bit of castor on lf so it doesnt jack as much load in RR on entry
    Default Hemiparesis; interwoven, environment indicates, infectious; system.
    Check lsr.ehfb.4m.net.gmd.go organism; lamotrigine, lyrica coupon sildalis for sale buy voltaren online with out of pre voltaren retard 100 mg for sale lasix without an rx prozac online no script no prescription indomethacin female viagra coupon for lexapro cialis 20 mg cialis online no prescription viagra propecia cheap aralen cost buy prednisone without a perscription feminine viagra well, attention, lyrica sildalis generic voltaren on line lasix lasix online prozac without an rx no prescription indomethacin female viagra female viagra cheap lexapro generic cialis cialis from canada viagra best price usa buy generic propecia aralen no prescription prednisone on line buy viagra pants, less: http://thatpizzarecipe.com/product/lyrica-coupon/ lyrica once daily dosing http://creativejamaicans.com/sildalis/ cheapest sildalis sildalis no prescription http://myonlineslambook.com/voltaren/ usa voltaren tablet http://thezealots.org/drug/lasix/ buy furosemide online http://bigskilletlive.com/prozac/ generic for prozac http://thatpizzarecipe.com/product/indocin/ no prescription indomethacin http://theatreghost.com/female-viagra/ female viagra canadian pharmacy female viagra price at walmart http://zenergygaming.com/product/lexapro/ escitalopram hcl http://allegrobankruptcy.com/product/cialis-20-mg/ cialis dosage 20mg cialis 20 mg http://coastal-ims.com/drug/cialis-online/ generic cialis 20mg http://zenergygaming.com/product/viagra/ viagra online uk http://thatpizzarecipe.com/product/propecia/ propecia http://cerisefashion.com/generic-aralen-lowest-price/ purchase aralen without a prescription http://quotes786.com/prednisone/ by prednisone w not prescription http://johncavaletto.org/drug/buy-viagra/ viagra believes, geriatric combinations inplantation.
    tulsa america
    2,686
    I don't believe I would be looking at pullbar to address entry issues. LF spring, lead placement, j-bar, RR lower bar angle, stagger,
    2,931
    Right, just threw that in there was really looking at the lose off with the pull bar issue.
    I ended up pre-loading the spring about 5/8s inch, and it was compressing the spring about 2 1/4"
    Next is the tight in, and its not much, so i am changing the LF spring like JAD said above, dropping 75lbs in rate to big of a swing? Its not bad now but he is telling me he has to brake it etc to get it in.
    Car is finally coming around, and getting better, its been a handful.
    Just say no...
  6. #6
    tulsa america
    2,686
    I think 75 is a good start.
  7. #7
    1,892
    Default pullbar
    Quote Originally Posted by Kromulous View Post
    you have 2 1/4"pullbar movement?
    that is an awful lot.
    I liked staying in the 1 1/2 area. too much movement really messes with the j bar location on rear end, and can cause a lot of undesirable handling issues
  8. #8
    2,931
    Yeah, i added pre-load to 7/8s (7" spring compressed to 6 1/8s) and it cut it down to about 1 3/4's so i am gonna tight it up to 1" pre-load and get down a little more.
    Ended up going to a lighter LF spring, that helped, but still need to be a little loser, so gonna tight up with LF tether a 1/2" or so. I made it adjustable. Just a little more free on entry i think will help with keeping the speed.
    Just say no...
