Results 1 to 7 of 7
    Dec 2007
    173
    Default Bronze bushing vs bearing birdcage
    Is there any advantage to bronze bushing birdcages vs bearing?
    Jun 2007
    228
    Bsb has a tech article talking about that on their website
    Batavia, OH
    13,615
    Quote Originally Posted by rick james View Post
    If your setup requires more lr damping, extra friction could get you there.
    Florence -1
    Dec 2007
    173
    Wasn't sure if side loading the bearings in the right side cage was a problem the were trying to solve with a bronze bushing
    Batavia, OH
    13,615
    My coilover is pretty square at race attitude. I guess if it's leaned in enough, maybe you could exceeds the allowable axial load. A guy could get tapered rollers.
    Florence -1
    Feb 2013
    413
    bloomer use to be big on the bronze bushings...
    Jun 2007
    Wisconsin
    307
    The problem with bronze bushings is that they require a ton of maintenance. You need to keep them greased and clean at all times. They do wear out tubes faster than bearings also. The good part is, if they are a real wide birdcage, they won't bind as bad as a bearing cage with axle tube flex. Also, make sure if you get bearing birdcages, be sure the bearings being used are of the best quality. We used the Wehrs machine cages for years without issue.
