Results 1 to 13 of 13
Thread: Brake lines
    Default Brake lines
    Whats the opinion on the plastic brake line kits, both push lock and compression fitting style. Looking for an easier way to do brake lines, absolutely hate a double flare tool, was considering going to a vise mounted one like eastwood sells, just pull A lever to make your flair.
    Dec 2007
    641
    we have used both steel lines and the plastic driver say he could not feel any difference.
    Nov 2014
    420
    I had the braided lined on a bwrc car I bought new. Came with a kit. All braided. Never good get a solid pedal. If you switched from 3 to 4 wheel. The first corner on 4 wheel was sketchy with the extra travel in the pedal all of a sudden.
    Batavia, OH
    11,720
    Plastic is sketchy at best.
    Droop isn't the problem.
    Arizona Speedway - 2 ........ Brushcreek -1
    Alltech -1 ........ Eldora -4
    East Bay - 6
    Florence -1
    Atomic -4
    Tazewell -1
    Moler -1
    Portsmouth -1
    Jun 2007
    Wisconsin
    270
    I'm not a fan of plastic brake lines; spongy pedal; prone to heat damage. Steel brake lines should last you the life of the car if you take the time to route them properly. I love my lever-style Eastwood flare tool.
    If anyone is ever going to build more than a couple of cars, it's worth the investment. I've had leaky flares with the standard old screw type of flaring tools. I've never had a problem with the lever type.
    The biggest thing is to make sure the end is square and bur free after you cut the line I use a file and a drill bit (with my hands) to clean up the end before flaring.
    Kansas
    1,594
    Quote Originally Posted by Ltemodel View Post
    On doing a flare: Agree with Kevin here (square on end and debur), but will add when you do the 2nd operation with the tapered wedge, DO NOT over tighten this part. Leaving extra compression available for the connected fitting to smash and seal will help a lot. 2nd would be to just use store bought length pieces (60" is the max length available) and just use unions if need longer to get from one place to another.
    Dec 2008
    thedirtysouth
    3,506
    I have not had my flaring tool out in years because I do exactly what billet is describing in his last sentence above....
    May 2010
    162
    Just paid 180$ on Amazon for a Eastwood *style* flare tool.. did the whole car in less than an hour. So useful and easy.
    Sep 2009
    717
    Braided lines are plastic too with a SS outer fabric.
    I do plastic, change it every couple years. Be smart where you run it and tie it down well and it's never been an issue for me.
  10. #10
    Batavia, OH
    11,720
    Quote Originally Posted by Lizardracing View Post
    Yup. That's why a whole car with braid has a spongy pedal.
    East Bay - 6
    Florence -1
    Atomic -4
    Tazewell -1
    Moler -1
    Portsmouth -1
  11. #11
    Mar 2018
    Macon GA
    166
    Longhorns from what IVe seen have aluminum brake lines with an AN fitting crimped on the end, no inverted flair anywhere. How do they do that? Custom made?
  12. #12
    Kansas
    1,594
    Quote Originally Posted by Burke1118 View Post
    Your not talking about a flare nut on solid line?
    This is typically done on a single flare (not a double flare - folded over 45 degree flare) and it generally only on stainless steel as a lesser material will break from vibration and split at the start of the flare and leak. while it will work on aluminum line, it breaks easy and is a disaster waiting to happen.
  13. #13
    Oct 2017
    1,174
    I've never seen aluminum brake lines and the connection type that billet is describing is generally used for low pressure applications such as fuel line. It is not rated for high hydraulic pressure that brake lines see
Copyright © 2021 vBulletin Solutions, Inc. All rights reserved.
