Results 1 to 6 of 6
Thread: Wheel spacers
    Aug 2018
    5,232
    Default Wheel spacers
    Whats up with all the 1/4-1/2 inch wheel spacers on both fronts? Is it clearance issues or fine tuning?
    Jul 2007
    538
    A spacer on the front end is a horrible thing to do in regards to how it effects front end geometry.
    Wouldn't a spacer only effect roll center? the caster, camber, ackerman, bump steer is all controlled by the linkage and mounts. Just wondering.
    Jul 2007
    343
    Quote Originally Posted by FlatTire View Post
    When Huey was alive and the MBH cars were stomping in Maryland and PA they ran a 1" wheel spacer on the RF.
    Owens had a one inch on his RF at Eldora.
    Without knowing key details you can't honestly say its a horrible thing to do.
    Batavia, OH
    13,634
    Quote Originally Posted by robbie35 View Post
    Scrub radius will be increased. Chassis will be lower to the ground for the same shock travel. Amount of weight transfer from caster will change as well. I'm sure I'm missing a bunch of other things.
    Atomic - 1
    I've liked a 1" on the RF when forced to run a hard tire rule, helps make a little RF heat. All good as long as you drive straight, seems like if you backsteer the RF spacer made the car worse.
