Results 1 to 2 of 2
    Dec 2012
    Northwest Indiana
    16,297
    Thumbs up KOKOMO (IN) - Kokomo Klash info posted.
    Kokomo Klash 15 presented by Allstar Performance Information
    Pre-registration will be required for all divisions.
    If you plan on racing this event you NEED TO REGISTER!
    Registration will open at 7PM Eastern on September 27th.
    Entries will be capped for the following divisions at the numbers listed below.
    Friday Night
    60 Thunder Cars
    Saturday Night
    40 Late Models
    80 Modifieds
    40 Sportsman
    80 Street Stocks
    60 Hornets
    Friday Night 10/15
    Pit Gates Open: 3PM
    Grandstands Open: 4PM
    Draw Closes/Drivers Meeting: 5:30PM
    Group Time Trials: 6PM
    Racing to follow
    General Admission: $20
    Pit Pass: $35 (all ages)
    Sprint Cars, Midgets & Thunder Cars will hotlap/group qualify for heat race starting positions.
    Thunder Cars will have to go through a quick tech before being allowed to draw.
    Racesaver 305 Sprints will use their series format for the evening.
    All Heats are 8 Lap
    B Mains are 10 Laps
    A Mains are 25 Laps
    Raindate 10/21 If Needed
    RaceCeivers REQUIRED in ALL divisions!
    All drivers must be 14 years of age or older to race.
    RACE TEAMS: Absolutely no saving of pit spots. You will be parked by track staff. If you want to be parked by someone, you must arrive at the same time
    Saturday Night 10/16
    Pit Gates Open: 11AM
    Grandstands Open: 3PM
    Draw Closes at 3PM
    Drivers Meeting: 3:30PM
    Group Time Trials: 4PM
    Racing to follow
    Late Models, Modifieds, Sportsman, Street Stocks & Hornets will hotlap/group qualify for heat race starting positions.
    Sportsman & Street Stocks will have to go through a quick tech before being allowed to draw.
    All Heats are 8 Lap
    B Mains are 10 Laps
    A Mains are 25 Laps
    CLASS RULES
    NON WING SPRINT CARS
    Rules:
    Hoosier Medium or Hoosier H15 on the Right Rear
    Other 3 corners are open to any Hoosier Tire
    AMB Transponders (red) will be used. Rental fee will be $10.00
    Payout:
    1. $2021.00
    2. $1000.00
    3. $700.00
    4. $500.00
    5. $400.00
    6. $350.00
    7. $300.00
    8. $285.00
    9. $275.00
    10. $260.00
    11. $255.00
    12. $250.00
    13. $240.00
    14. $230.00
    15. $225.00
    16. $220.00
    17. $215.00
    18. $210.00
    19. $205.00
    20. $200.00
    21. $200.00
    22. $200.00
    B-Main Non-Transfer: $50
    USAC Regional MIDGETS
    Rules:
    National & D2 midgets are legal
    Hoosier Tire mandatory on all four corners
    $100.00 bonus to the highest finishing D2 legal car
    Payout:
    1. $1221.00
    2. $600.00
    3. $350.00
    4. $300.00
    5. $250.00
    6. $215.00
    7. $200.00
    8. $175.00
    9. $160.00
    10. $150.00
    11. $150.00
    12. $150.00
    13. $150.00
    14. $150.00
    15. $150.00
    16. $150.00
    17. $125.00
    18. $125.00
    19. $125.00
    20. $125.00
    21. $125.00
    22. $125.00
    B-Main Non-Transfer : $50.00
    IMCA Indiana Racesaver SPRINT CARS
    Rules:
    Series Rules in effect
    Payout:
    1. $621.00
    2. $350.00
    3. $250.00
    4. $225.00
    5. $200.00
    6. $195.00
    7. $190.00
    8. $185.00
    9. $180.00
    10. $175.00
    11. $170.00
    12. $165.00
    13. $160.00
    14. $150.00
    15. $150.00
    16. $150.00
    17. $150.00
    18. $150.00
    19. $150.00
    20. $150.00
    21. $150.00
    22. $150.00
    THUNDER CARS
    Rules:
    DOT Tires Only (NO RACING TIRES)
    Must run gauge legal 500 CFM 4412 Holley unaltered carburetor
    Factory Stock Steel style OEM Body (no aluminum or fiberglass hoods or trunk lids or plastic fenders)
    Aftermarket Nose & Bumper Covers allowed (no open tail sections, no partially opened tail sections, no added drilled holes in tail section. It must be completely closed.)
    3200 LBS minimum weight
    Must have OEM stock floor pan (non OEM stock floor pans must be steel, with 50 pounds mounted near floor pan)
    Stock OEM Frames ONLY
    Steel blocks & steel heads ONLY (headers allowed)
    Aluminum intake must have 25 pounds mounted in front of the motor plate
    No aftermarket racing transmissions allowed (Bert, Brinn, Falcon)
    No direct drives
    Chevrolet engines will be permitted a maximum displacement of 360.4 c.i.d.
    Ford engines will be permitted a maximum displacement of 362 c.i.d.
    360 Chrysler engines will be permitted a maximum displacement of 367 c.i.d.
    Top 5 finishers may have engines pumped
    Maximum 8 inch wheel width
    Stock Rear Suspension Only (Aftermarket Shocks, Springs & Ford 9 inch rear ends allowed in stock OEM mounting location)
    Rear Weight Jacks are allowed (no front weight jacks)
    Front Shocks must be mounted in OEM position
    If a fabricated steel firewall is used 25lbs of weight must be evenly added to the outer edge of the left & right side of the front side of the firewall for a total of 50lbs. The car must weigh 3250lbs with a fabricated steel fire wall.
    Maximum 4 inch spoiler allowed
    Westhold Transponders (yellow) will be used. Rental fee will be $10.00
    ALL cars MUST have a transponder pouch. This is MANDATORY!
    Payout:
    1. $421.00
    2. $250.00
    3. $200.00
    4. $175.00
    5. $150.00
    6. $125.00
    7. $110.00
    8. $100.00
    9. $90.00
    10. $80.00
    11. $80.00
    12. $70.00
    13. $60.00
    14. $60.00
    15. $60.00
    16. $60.00
    17. $60.00
    18. $60.00
    19. $60.00
    20. $60.00
    21. $60.00
    22. $60.00
    23. $60.00
    24. $60.00
    B-Main Non-Transfer: $35
    LATE MODELS
    Rules:
    Open tire rule on all four corners
    UMP Body Rules
    Open Motors 2300 LBS minimum weight
    Steel Block 2250 LBS minimum weight
    Crate Motors 2200 LBS minimum weight
    Payout:
    1. $2021.00
    2. $1000.00
    3. $700.00
    4. $500.00
    5. $400.00
    6. $350.00
    7. $300.00
    8. $285.00
    9. $275.00
    10. $260.00
    11. $255.00
    12. $250.00
    13. $240.00
    14. $230.00
    15. $225.00
    16. $220.00
    17. $215.00
    18. $210.00
    19. $205.00
    20. $200.00
    21. $200.00
    22. $200.00
    Allstar Performance MODIFIEDS
    Rules:
    UMP & IMCA style cars are legal
    Hoosier M30 & M60 tires are legal
    IMCA G60 tire legal
    Payout
    1. $1122.00
    2. $600.00
    3. $400.00
    4. $350.00
    5. $325.00
    6. $300.00
    7. $275.00
    8. $265.00
    9. $260.00
    10. $250.00
    11. $235.00
    12. $230.00
    13. $225.00
    14. $220.00
    15. $215.00
    16. $210.00
    17. $210.00
    18. $210.00
    19. $210.00
    20. $210.00
    21. $210.00
    22. $210.00
    23. $210.00
    24. $210.00
    SPORTSMAN
    Rules:
    Open Tire Rule
    Indiana Super Stock Style Body Rules
    2800 LBS minimum weight
    Stock Front Clip Cars ONLY (No all tube cars)
    NO ALUMINUM BLOCKS OR HEADS ALLOWED
    Maximum engine set back is 4" from the #1 spark plug to the middle of the ball joint
    Maximum 10 inch wheel width.
    Maximum tire tread width is 10 inch. (Foot print measured from outside edge to outside edge). -
    No shaving/edging of tires to obtain 10 inch tread width.
    Michigan Dirt Pro Stocks aftermarket front subs are legal
    Payout:
    1. $821.00
    2. $400.00
    3. $300.00
    4. $250.00
    5. $225.00
    6. $200.00
    7. $175.00
    8. $165.00
    9. $160.00
    10. $150.00
    11. $135.00
    12. $130.00
    13. $125.00
    14. $120.00
    15. $115.00
    16. $110.00
    17. $110.00
    18. $110.00
    19. $110.00
    20. $110.00
    21. $110.00
    22. $110.00
    B-Main Non-Transfer: $40
    Allstar Performance STREET STOCKS
    Rules:
    Stock appearing bodies only (aftermarket five star style allowed)
    Minimum roof height 50 inches & Maximum roof height 56 inches at highest point.
    Maximum Roof Rake front to rear is 3 inches
    3000 LBS minimum weight
    Stock OEM frames (uni-body cars allowed) (Rear frame may be replaced from rear shock mounts back)
    Maximum Engine set back is #1 spark plug aligned with the center of the upper ball joint
    No aluminum blocks or heads allowed
    Maximum 8 inch spoiler allowed
    Weight jacks allowed
    Rear Bumper covers or Filler Panels must cover the entire width of the car. (No open or partially open rear ends)
    Payout
    1. $721.00
    2. $375.00
    3. $275.00
    4. $250.00
    5. $225.00
    6. $215.00
    7. $205.00
    8. $195.00
    9. $185.00
    10. $175.00
    11. $170.00
    12. $165.00
    13. $155.00
    14. $145.00
    15. $135.00
    16. $135.00
    17. $135.00
    18. $135.00
    19. $135.00
    20. $135.00
    21. $135.00
    22. $135.00
    23. $135.00
    24. $135.00
    HORNETS
    Rules:
    Open to any FWD or RWD 4 Cylinder car
    OEM frame & chassis only
    OEM steel & plastic bodies (aftermarket bumper covers ok) full fabricated bodies are not legal
    No aluminum bodies
    Trunks lids/hatch must be on the car, no open rear ends
    No spoilers
    DOT tires only (no racing tires)
    Headers OK
    Hartford Speedway Cyber Stocks (4 & 6 Cylinder) are legal
    Payout:
    1. $421.00
    2. $200.00
    3. $150.00
    4. $125.00
    5. $115.00
    6. $110.00
    7. $100.00
    8. $90.00
    9. $80.00
    10. $70.00
    11. $70.00
    12. $60.00
    13. $50.00
    14. $50.00
    15. $50.00
    16. $50.00
    17. $50.00
    18. $50.00
    19. $50.00
    20. $50.00
    21. $50.00
    22. $50.00
    23. $50.00
    24. $50.00
    B-Main Non-Transfer: $30
    Next Race - TBA
    2024 Season: 3 - Brownstown (IN) 1, Farmer City (IL) 1, & Kankakee (IL) 1
    Dec 2012
    Northwest Indiana
    16,297
    Kokomo Klash registration is open for both nights.
    Friday & Saturday
    Link below.
    https://www.myracepass.com/tracks/18...7CHhynAOTIwokY
    Next Race - TBA
