Results 1 to 5 of 5
Thread: XR1 Help
    Mar 2017
    5
    Default XR1 Help
    So have a 2020 xr1 with super motor and run 1300 tires all 4 corners. The car is so freaking tight in the mud.. Hard to get it to turn on gas.. have to jam brakes and hope it turns.. can someone help in this aspect of how to get it to turn and rotate better.. Also struggle in slick with how much to do even tho rocket says just take load out of rr.. here’s my loads and spring comboLf 525 650Rf 200/700 18.25 680 3”1238 4” 1639 5” 2600Lr 22.625 250Rr 450 2 rubbers This is on a fast banked 3/8 in southern ohio thanks
    Mar 2017
    5
    You can pm me if wanna keep it confidential thanks
    Batavia, OH
    13,666
    I can't get the math to work on your rf load numbers. Is there a spring rubber in there somewhere?
    You can't get from ride to 3" without hitting a lock out (too much load gain for just stack). But then 3" to 4" is less than 700#.
    Atomic - 2
    Mar 2017
    5
    Sorry idk where I got that from18.250 7003”13004”16565”2560
    Mar 2017
    5
    18.25 700. 3” 1300. 4” 1656 5” 2560Sorry doing this with phone and not letting me fix postAll rods r in rocket standard holes
