Results 1 to 5 of 5
Thread: Rear end grease
    Feb 2021
    7
    Default Rear end grease
    What fluid is recommended in a quick change rear end
    Jul 2013
    Lost, but way ahead of schedule
    1,514
    DMI has their own stuff, a 75-90w synthetic. Looks like Winters recommends 70-90, semi or full synthetic.
    Oct 2017
    1,368
    Winters and dmi both have some proprietary stuff.i think they are equal in quality. I've seen people run just about every gear lube you could imagine without much consequence but you are technically supposed to run lube designed for a hypoid ring and pinion setup their are lube that are not rated for hypoid use
    Jun 2007
    Wisconsin
    307
    I always liked either Gibbs or Schaffers. I was told once, by a guy who built rear ends for NASCAR, that the most important aspect is to keep it clean and change it often.
    Feb 2015
    901
    Over the years we've tried about everything from the cheapos to outrageous and, like jking says, seen little difference. We have almost always run the hypoid r&p stuff and have generally settled on the Stalube 80-90 we get at NAPA for a cheap for now-a-days price. Been our go to for around 25 years now.
