Fuel Tank Foam
Is the Yellow Fuel Tank Foam in Fuel Safe tank compatible with Methanol?
o.show
I use wiffle balls instead of foam and no many others use them with methanol.
28 gallon cell takes approx. 240 wiffle balls
o.show
https://fuelsafe.com/fbk/ click on questions at the bottom of this page and you will see this response from fuel safe
Allan B.
Verified Reviewer
10/27/22
Q: Is this Foam compatible with Methanol Fuel?
Answers (1)
Fuel Safe
10/27/22
A: Hi Allan,
No, this foam is not compatible with 100% methanol. It is compatible with any fuel blend that has up to an 85% ethanol content or less.
