Results 1 to 8 of 8
Thread: Rf chain
    Aug 2018
    5,234
    Default Rf chain
    I saw one on a new Harris mod. Are they being used on any dlms?
    Batavia, OH
    13,638
    Quote Originally Posted by ZERO25 View Post
    If you need one, something is seriously wrong. That's all I got to say about that.
    Atomic - 2
    2,931
    Softer spring with Preload on Mods, so stopping the droop helps getting the shock off easy. Since the spring and shock are seperate. The geometry of the clips produce a lot of droop travel thats useless.
    Just say no...
    Aug 2018
    5,234
    Youre probly right, it had 4-6 inches of adj.
    Quote Originally Posted by MasterSbilt_Racer View Post
    it might be seriously wrong...but those harris cars are seriously fast. currently leading imca national points and won the USMTS opener
    Batavia, OH
    13,638
    Quote Originally Posted by outlaw4j View Post
    I was addressing the use on a late model, specifically. The non-racing use on a mod makes sense.
    Atomic - 2
    May 2009
    1,336
    Using them on alot of stock clip applications, it’s a way to run soft but still have some rate in your 1-2” travel range so you don’t crash through your travel. The spring acts stiff until it overcomes the preload in the chain. It’s the same concept as like a Joes Racing Preloader.
    Batavia, OH
    13,638
    ^^your spring is actually rated at infinity, until your preload is overcome.
    Atomic - 2
