Results 1 to 6 of 6
Thread: ARS Shocks
    Sep 2010
    159
    Default ARS Shocks
    Has anyone used the small body RR with the dual spring setup?
    796
    yes i have one. it's decent, nothing magic. can't put rubbers in it so that sucks.
    Sep 2010
    159
    Do you notice any difference using it versus a single spring with spring rubbers?
    Batavia, OH
    13,635
    Just set up a dual rate deal on a normal shock and copy their loads. Then you have the same thing and can add rubbers, if that's your normal thing to do.
    Atomic - 1
    Batavia, OH
    13,635
    Quote Originally Posted by mab475 View Post
    The more your car lifts the rr on corner exit, the more you will notice a difference.
    Atomic - 1
    796
    Yes. On a slick bottom to top track with no cushion was where it was best. Keeping load in the RR spring off the corner was good. It's similar to chaining your RR so it stays in the spring except you aren't restricting the rear movement with the chain.
    I just feel that you have to have a very specific track condition for it and unfortunately I don't get that very often where I race.
