Results 1 to 10 of 10
    SHAWANO, WI
    145
    Default Best cast iron head
    putting together a sbc latemodel motor thats all cast iron, roller cam,dome pistons, 388ci on alcohol with peak rpm at 8200. whats the best choice, im looking at 220 motowns, 215 dart platinums and eq220 , let me know what you guys think or other reccomendations, thanks.
    west virginia
    547
    the best steel head is the 14 degree from rhs (used to be pro topline)
    SHAWANO, WI
    145
    23 degree only
    Mar 2008
    Cartersville,GA
    493
    Large Port Bowtie Vortec...If using on a big bore(for example 4.155 or larger) I would reccomend O-ringing block
    http://www.chevyhiperformance.com/te...ine/index.html
    SHAWANO, WI
    145
    30 over 350 block is what were using, just want the best head for the money
  6. #6
    Sep 2007
    511
    RHS raised runner 23*
  7. #7
    if you are aloud porting i would get a set of dart plats from rons porting service
  8. #8
    west virginia
    547
    rons stuff is pretty good
  9. #9
    Dec 2010
    7
    in 05 we made 640 with a no roller 415 iron 23deg using a set of RONS !!! and didnt need 8200, stayed around 7600
  10. #10
    Pa
    486
    Lg. port vortech is the best choice to me we made 590 hp on a 355 flat tappet on alky a 388 roller you should be able to get at least 610 hp on that. JMO
