carb is all set up fine and everything else is brand new
so set it at 5.5 and tht all i need not 9 to 12crapping on it self on top end wont turn rpm with the system i have is the issue
i know i turn 8000 on gas and now on allky wont do it
Originally Posted by
grydergeyer26
carb is all set up fine and everything else is brand new so set it at 5.5 and tht all i need not 9 to 12crapping on it self on top end wont turn rpm with the system i have is the issue i know i turn 8000 on gas and now on allky wont do it
You don't need all that. Set it at 5.5, make sure float is set properly and let it eat.If its missing up top I'd be looking elsewhere. On the 4 popper if its lean up top it will feel like you threw out an anchor or like your dragging the brake. Shut it down because it won't last long if its doing that. More likely that you have some other issue.
BUCKLE UP NOW, YA HEAR?
st i at wide open or at idleat 5.5 and i that for any engine
