Results 1 to 4 of 4
    Nov 2013
    6
    Default The Last NEW Russell Baker 430 13 degree priced to sell
    Priced thousands below cost. This is the last new engine Russell was working on before he passed. Final assembly done by Scott Bailey and Brian Baker. 430 13 degree, all aluminum dart block, 50 mm roller cam bearings, cnc dart heads, Sonny Bryant crank, dyers rods, ATI dampner, Jones pulley, serp drive, Edelbrock water pump, msd pro billet distributer and crank trigger, t&d rocker arms, Dan Olson oil pan, billet valve covers with built in spring oilers, the best of everything priced $10,000.00 below cost. Contact Scott Bailey 816-665-2415 Price $27,000.00
    Can this engine be run on alky and wat sort of HP would it produce
    Mar 2014
    4
    yes it can be run on alcohol and it will produce around 850 HP this is sb-2's wife his acct won't let him in at the moment you may contact via email jennifer.bailey1322@yahoo.com or his cell 816-665-2415
    Mar 2014
    4
    Price Dropped to $26,000
