Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    267
    Default Rocket Parts $ 4 SALE $
    Rocket lift bar
    Rocket 6th coil spring set up
    Rocket J bar
    Sweet rack for rockets. 18 3/4 19 3/4 combo 3.75
    Sweet rack for rocket 18 3/4
    Used lowers
    Used uppers
    Traction Shock
    5th coil shock
    17" kirky seat
    Used rear mount starters
    used fuel pumps
    used brake pads for wilwood calipers
    used radiators
    Blake or Brazwell carb
    used gun drilled axles
    propower 18 degree 390ci chevy
    18 degree headers
    grt 7th coil
    grt clamp brackets
    grt z-link brackets
    Fibertec roof
    used springs
    used 16 volt batteries
    Weld bead and non bead rims.
    Used 40's and 55's hooisers
    Sep 2007
    328
    How much for battery
    whats the 5th coil shock and how much? thanks
    267
    The batteries have no charge and need to be brought back to life $25 each. The shock is not non adjustable integra with shrader valve. $100
    Interested in traction shock what is it..and how much
  6. #6
    109
    how much for uppers and lowers and what kind shape are they in are they for blue front thanks
  7. #7
    267
    they are used. uppers alittle tight and the lowers have the left right stud before the heim end. They don't have good ball joints if they have them. Yes blue front. Uppers $20 lowers $60 Rocket stuff.
  8. #8
    Mar 2010
    Wisconsin
    190
    What length axes do you have for sale?
  9. #9
    267
    what you looking for?
  10. #10
    267
    I have a solid titanium 35 1/2 axle. A few 34 solid steel axles
  11. #11
    267
    shock and 6th coil setup sold
  12. #12
    what bolt pattern are headers and how much thanks izzy9
  13. #13
    267
    $100 7 bolt pattern up down.
  14. #14
    267
    Racks $350 each.
    LOts to sell Make offers
  15. #15
    267
    btt ^^^^^^^^^^^^^^^^^
  16. #16
    Oct 2008
    17
    I am looking for a spare rack for a Blue/Grey front Rocket. Can you send me pics and ratio of racks to greggh@microage-chatham.com
    Thanks.
  17. #17
    267
    Sorry, been busy busy. Haskell21 Still need pics?
  18. #18
    267
    Lots to sell, Still have alum 380 propower engine.
  19. #19
    Aug 2007
    388
    Radiator hold down assembly??
  20. #20
    Can u text pics of motor to 740-444-1874
