2015 Rocket Blue Front Roller
2015 Rocket Blue Front Roller For Sale: 22 races, Docol Tubing, Frankland 4.11 REM Finished Rear, Rocket Roller Bearing Birdcages, Rocket Pinion Mount, Keyser Aluinum J-Bar, Rocket Frame Slider, Rocket Solid Lift Bar, Rocket Mid Plate, Rocket Serrated Spindles, Rocket Lowers, Howe Low Friction Ball Joints, Keyser Low Friction Uppers, Teflon Heims, Swagged Tubes throughout, Sweet Rack, Sweet Collapsible Steering Shaft, Sweet 15" Flat Steering Wheel, Wilwood Floating XD Hubs, Stainless Rotors, Wilwood NDP Calipers, LW Drive Flanges, Strange Axles, REM Finished Wheel Bearings, Bearing Spacers, Quick Car Gauges, Tel Tac, Rocket Wiring Harness, Wilwood Brake and Clutch Pedals, Coleman Throttle Pedal, 2 Lever Shifter with Rods, 6AL MSD, MSD HVC Coil, XS Power, Fuel Safe Fuel Cell, LW Fuel Line. no Wheels or Tires, no Seat, no Drive Line, no Shocks or Springs, no Oiling System, can leave Oil Tank. $18,500.00. Call Robbie at Rocket or 304-677-3929
