Results 1 to 7 of 7
Thread: Deck height
    Apr 2011
    224
    Default Deck height
    Older car. oil double adjustable shocks. Standard single spring in every corner. With current setup and me in the car, deck height is just under 40, which is fine most places. ULMS tech states 39", to be measured at tech inspection and before each race. Without changing all ride heights and losing a ton of turns in the LR, I can't make that happen. What should I do?
    What spring is on your LR?
    Batavia, OH
    13,690
    Quote Originally Posted by dfhotlm33c View Post
    Is your t bar not adjustable? I've never seen a car that couldn't go down that much.
    Florence -3
    Moler - 1
    799
    Just buy the Wehr's deck adjuster inserts
    Jan 2008
    132
    Lower the deck if you are happy with the car’s handling.
  6. #6
    Apr 2011
    224
    T-bar did it. Don't know why I didn't look at that. Thanks.
  7. #7
    Batavia, OH
    13,690
    Glad that fixed it!
    Florence -3
    Moler - 1
