No rpm out of motor
Motor will not turn past 6500. 358 steel headed flat top piston with flat tappet cam good to 7000.
Change coil, module, plugs, and 3 different jet. Does have a 500 4412 carb
white trash motorsports
Originally Posted by
Racingtoad
did you set the cam to spec or just put it in.if advanced to much would not turn up. even worse if you running a 500.
Ditto on the valve springs! Good luck
