Originally Posted by
Bottomfeeder17
I've been reading this morning and couldn't find alot of info on putting a bump stop on the left rear behind shock. I am new to late models but couldn't you run a lower rate spring/springs and add a bump to get your desired ride height and load without effecting your expanded load number? or would this be sluggish trying to left the left rear versus a traditional load from the springs?
Yes, you can. Actually, if you have a spring rate in the less than 100# range, I find you pretty much have to.
Atomic - 1
