Quick change tubes
What length tubes are needed to make a 60 centered i have one with aluminum tubes and need to order some steel tubes thanks
What hub are you using? I build steel tubes .Birdcages fitted to a 3.008 bearing so you will not need to do any work to the tubes . 563-659-1153
5x5 gn hubs. right now it has aluminum late model tubes in it. thanks
Most tubes are sold in one length and you cut them to the size you need.
would that be 24'' from bearing seat to end of tube or overall length thanks..
Originally Posted by
mudeater18
Not sure where you heard this but it is not correct. They are sold in 1 inch increments.
http://www.outlawraceparts.com/produ...-1480-151.html
NRP
24" tubes 30.5" axles
Unless QC 's are different than a 9" 30.5 axles are incorrect for a 60" centered. For a 60" centered you need a 32.5 on the right and a 28.5 on the left.
24 inch tubes & 30.5 inch axles.....just put in a quickchange last year.
dirttrackrocker
yokes are centered on a QC and are offset on a 9 inch
as stated,QC yokes are centered,..and if you change tubes,..youll need to change to the right length axles... http://static.speedwaymotors.com/ima...rt-9197334.gif
next thing youll need to consider is if ya want GN hubs or wide5s...good luck...
white trash motorsports
twisterf5
Ah..... Gotcha...
Egoracing
[url]
We must use a different brand then. I've bought and installed a half dozen or so and all were cut to length.
My tubes that I build are custom length or made long so you can cut to the length you need,should use the end of tube to the inner bearing seat for a length.
