KOKOMO (IN) - Kokomo Klash info posted.
Kokomo Klash 15 presented by Allstar Performance Information
Pre-registration will be required for all divisions.
If you plan on racing this event you NEED TO REGISTER!
Registration will open at 7PM Eastern on September 27th.
Entries will be capped for the following divisions at the numbers listed below.
Friday Night
60 Thunder Cars
Saturday Night
40 Late Models
80 Modifieds
40 Sportsman
80 Street Stocks
60 Hornets
Friday Night 10/15
Pit Gates Open: 3PM
Grandstands Open: 4PM
Draw Closes/Drivers Meeting: 5:30PM
Group Time Trials: 6PM
Racing to follow
General Admission: $20
Pit Pass: $35 (all ages)
Sprint Cars, Midgets & Thunder Cars will hotlap/group qualify for heat race starting positions.
Thunder Cars will have to go through a quick tech before being allowed to draw.
Racesaver 305 Sprints will use their series format for the evening.
All Heats are 8 Lap
B Mains are 10 Laps
A Mains are 25 Laps
Raindate 10/21 If Needed
RaceCeivers REQUIRED in ALL divisions!
All drivers must be 14 years of age or older to race.
RACE TEAMS: Absolutely no saving of pit spots. You will be parked by track staff. If you want to be parked by someone, you must arrive at the same time
Saturday Night 10/16
Pit Gates Open: 11AM
Grandstands Open: 3PM
Draw Closes at 3PM
Drivers Meeting: 3:30PM
Group Time Trials: 4PM
Racing to follow
Late Models, Modifieds, Sportsman, Street Stocks & Hornets will hotlap/group qualify for heat race starting positions.
Sportsman & Street Stocks will have to go through a quick tech before being allowed to draw.
All Heats are 8 Lap
B Mains are 10 Laps
A Mains are 25 Laps
CLASS RULES
NON WING SPRINT CARS
Rules:
Hoosier Medium or Hoosier H15 on the Right Rear
Other 3 corners are open to any Hoosier Tire
AMB Transponders (red) will be used. Rental fee will be $10.00
Payout:
1. $2021.00
2. $1000.00
3. $700.00
4. $500.00
5. $400.00
6. $350.00
7. $300.00
8. $285.00
9. $275.00
10. $260.00
11. $255.00
12. $250.00
13. $240.00
14. $230.00
15. $225.00
16. $220.00
17. $215.00
18. $210.00
19. $205.00
20. $200.00
21. $200.00
22. $200.00
B-Main Non-Transfer: $50
USAC Regional MIDGETS
Rules:
National & D2 midgets are legal
Hoosier Tire mandatory on all four corners
$100.00 bonus to the highest finishing D2 legal car
Payout:
1. $1221.00
2. $600.00
3. $350.00
4. $300.00
5. $250.00
6. $215.00
7. $200.00
8. $175.00
9. $160.00
10. $150.00
11. $150.00
12. $150.00
13. $150.00
14. $150.00
15. $150.00
16. $150.00
17. $125.00
18. $125.00
19. $125.00
20. $125.00
21. $125.00
22. $125.00
B-Main Non-Transfer : $50.00
IMCA Indiana Racesaver SPRINT CARS
Rules:
Series Rules in effect
Payout:
1. $621.00
2. $350.00
3. $250.00
4. $225.00
5. $200.00
6. $195.00
7. $190.00
8. $185.00
9. $180.00
10. $175.00
11. $170.00
12. $165.00
13. $160.00
14. $150.00
15. $150.00
16. $150.00
17. $150.00
18. $150.00
19. $150.00
20. $150.00
21. $150.00
22. $150.00
THUNDER CARS
Rules:
DOT Tires Only (NO RACING TIRES)
Must run gauge legal 500 CFM 4412 Holley unaltered carburetor
Factory Stock Steel style OEM Body (no aluminum or fiberglass hoods or trunk lids or plastic fenders)
Aftermarket Nose & Bumper Covers allowed (no open tail sections, no partially opened tail sections, no added drilled holes in tail section. It must be completely closed.)
3200 LBS minimum weight
Must have OEM stock floor pan (non OEM stock floor pans must be steel, with 50 pounds mounted near floor pan)
Stock OEM Frames ONLY
Steel blocks & steel heads ONLY (headers allowed)
Aluminum intake must have 25 pounds mounted in front of the motor plate
No aftermarket racing transmissions allowed (Bert, Brinn, Falcon)
No direct drives
Chevrolet engines will be permitted a maximum displacement of 360.4 c.i.d.
Ford engines will be permitted a maximum displacement of 362 c.i.d.
360 Chrysler engines will be permitted a maximum displacement of 367 c.i.d.
Top 5 finishers may have engines pumped
Maximum 8 inch wheel width
Stock Rear Suspension Only (Aftermarket Shocks, Springs & Ford 9 inch rear ends allowed in stock OEM mounting location)
Rear Weight Jacks are allowed (no front weight jacks)
Front Shocks must be mounted in OEM position
If a fabricated steel firewall is used 25lbs of weight must be evenly added to the outer edge of the left & right side of the front side of the firewall for a total of 50lbs. The car must weigh 3250lbs with a fabricated steel fire wall.
Maximum 4 inch spoiler allowed
Westhold Transponders (yellow) will be used. Rental fee will be $10.00
ALL cars MUST have a transponder pouch. This is MANDATORY!
Payout:
1. $421.00
2. $250.00
3. $200.00
4. $175.00
5. $150.00
6. $125.00
7. $110.00
8. $100.00
9. $90.00
10. $80.00
11. $80.00
12. $70.00
13. $60.00
14. $60.00
15. $60.00
16. $60.00
17. $60.00
18. $60.00
19. $60.00
20. $60.00
21. $60.00
22. $60.00
23. $60.00
24. $60.00
B-Main Non-Transfer: $35
LATE MODELS
Rules:
Open tire rule on all four corners
UMP Body Rules
Open Motors 2300 LBS minimum weight
Steel Block 2250 LBS minimum weight
Crate Motors 2200 LBS minimum weight
Payout:
1. $2021.00
2. $1000.00
3. $700.00
4. $500.00
5. $400.00
6. $350.00
7. $300.00
8. $285.00
9. $275.00
10. $260.00
11. $255.00
12. $250.00
13. $240.00
14. $230.00
15. $225.00
16. $220.00
17. $215.00
18. $210.00
19. $205.00
20. $200.00
21. $200.00
22. $200.00
Allstar Performance MODIFIEDS
Rules:
UMP & IMCA style cars are legal
Hoosier M30 & M60 tires are legal
IMCA G60 tire legal
Payout
1. $1122.00
2. $600.00
3. $400.00
4. $350.00
5. $325.00
6. $300.00
7. $275.00
8. $265.00
9. $260.00
10. $250.00
11. $235.00
12. $230.00
13. $225.00
14. $220.00
15. $215.00
16. $210.00
17. $210.00
18. $210.00
19. $210.00
20. $210.00
21. $210.00
22. $210.00
23. $210.00
24. $210.00
SPORTSMAN
Rules:
Open Tire Rule
Indiana Super Stock Style Body Rules
2800 LBS minimum weight
Stock Front Clip Cars ONLY (No all tube cars)
NO ALUMINUM BLOCKS OR HEADS ALLOWED
Maximum engine set back is 4" from the #1 spark plug to the middle of the ball joint
Maximum 10 inch wheel width.
Maximum tire tread width is 10 inch. (Foot print measured from outside edge to outside edge). -
No shaving/edging of tires to obtain 10 inch tread width.
Michigan Dirt Pro Stocks aftermarket front subs are legal
Payout:
1. $821.00
2. $400.00
3. $300.00
4. $250.00
5. $225.00
6. $200.00
7. $175.00
8. $165.00
9. $160.00
10. $150.00
11. $135.00
12. $130.00
13. $125.00
14. $120.00
15. $115.00
16. $110.00
17. $110.00
18. $110.00
19. $110.00
20. $110.00
21. $110.00
22. $110.00
B-Main Non-Transfer: $40
Allstar Performance STREET STOCKS
Rules:
Stock appearing bodies only (aftermarket five star style allowed)
Minimum roof height 50 inches & Maximum roof height 56 inches at highest point.
Maximum Roof Rake front to rear is 3 inches
3000 LBS minimum weight
Stock OEM frames (uni-body cars allowed) (Rear frame may be replaced from rear shock mounts back)
Maximum Engine set back is #1 spark plug aligned with the center of the upper ball joint
No aluminum blocks or heads allowed
Maximum 8 inch spoiler allowed
Weight jacks allowed
Rear Bumper covers or Filler Panels must cover the entire width of the car. (No open or partially open rear ends)
Payout
1. $721.00
2. $375.00
3. $275.00
4. $250.00
5. $225.00
6. $215.00
7. $205.00
8. $195.00
9. $185.00
10. $175.00
11. $170.00
12. $165.00
13. $155.00
14. $145.00
15. $135.00
16. $135.00
17. $135.00
18. $135.00
19. $135.00
20. $135.00
21. $135.00
22. $135.00
23. $135.00
24. $135.00
HORNETS
Rules:
Open to any FWD or RWD 4 Cylinder car
OEM frame & chassis only
OEM steel & plastic bodies (aftermarket bumper covers ok) full fabricated bodies are not legal
No aluminum bodies
Trunks lids/hatch must be on the car, no open rear ends
No spoilers
DOT tires only (no racing tires)
Headers OK
Hartford Speedway Cyber Stocks (4 & 6 Cylinder) are legal
Payout:
1. $421.00
2. $200.00
3. $150.00
4. $125.00
5. $115.00
6. $110.00
7. $100.00
8. $90.00
9. $80.00
10. $70.00
11. $70.00
12. $60.00
13. $50.00
14. $50.00
15. $50.00
16. $50.00
17. $50.00
18. $50.00
19. $50.00
20. $50.00
21. $50.00
22. $50.00
23. $50.00
24. $50.00
B-Main Non-Transfer: $30
Next Race - TBA
2024 Season: 3 - Brownstown (IN) 1, Farmer City (IL) 1, & Kankakee (IL) 1
You forgot a period.
Not my problem. I just copied and pasted from the track Facebook page. Thanks for the heads up though. I'll look in to it.
Next Race - TBA
Kokomo Klash registration is open for both nights.
Friday & Saturday
Link below.
https://www.myracepass.com/tracks/18...7CHhynAOTIwokY
Next Race - TBA
Whooosh
Head
Saturday Show - (Entries are capped due to space parking the cars)
LATE MODELS (40) FULL
05B Josh Boller
D1 Turk Letizia
P3x Steve Peeden
P3 Jeff Robertson
7 Chad Gross
8m Matt Gifford
8 Dan Richardson
9LT Jacob VanDeVoorde
9z Jayme Zidar
11X Ryan Lanphierd
B14 Victor Benedetto
14BG Britan Godsey
14N Tyler Norton
19 Derrick Hilliker
19m Carter Murday
20A Kory Maurice
20M Josh Morton
20 Chad White
20w Justin White
21d David Hilliker
22 Ian Palmer
22J Jace Owens
23c Keegan Cox
24b Kyle Cooper
25 Ted Johnson
28 Matt Adkins
33 Dave Bowen
P33 Josh Robertson
44M Josh Barrett
45 Travis Abbott
49 Brian Ruhlman
51 Steve Fairbanks
53 Hillard Miller
67 Scott Robertson
71D Drew Smith
71 Joe Smith
71s Rusty Smith
74 Dan DeYoung
91 Rusty Schlenk
99 Bill Sheets
MODIFIEDS (80 entries. 76 entered so far) 4 Spots Left
0J Garrett Jameson
0no Jamie Layton
0 Tim Wilber
08 Dan Streeter
1E Jeff Erickson Jr
1 Dave Lilja
1w Bob Pohlman
2B Brent Hudson
3w Dylan Woodling
4 Logan Beckwith IV
4c Tom Cox
4M Tim Monroe
5H Joshua Hotsinpiller
5cs Curt Spalding
7N Mike Nelson
8c Corey Bevard
9 Todd Nelson
9 Garrett Rons
11 Roger Cavness
11ts Tyler Spalding
13 Nathan Krengle
M14 Scott Martin
15j Jimmy Hayden
17N Dillon Nusbaum
19 Austin Dryer
R19 Ryan Ramseyer
21A Nick Allen
22t Tony Anderson
22 Will Bennett
23B Ethan Boomsma
24h Steven Hogue
25 Josh Lolmaugh
25S Jake Straka
27c Justin Cundiff
27 Beau DeYoung
27K Kevin DeYoung
27j Jason Jones
28 Jeff Deckard
28M Frank Marshall
29j Jordan Weaver
32 Mason Duncan
34t Tanner Reed
34w James Walters
35HT Hayden Tanner
38 Tim Sullivan
42 Pete Argianas
44 Andy Sherley
45 Robby Henderson
46 John Warner
49 Brian Ruhlman
51 Rob Brickert
52 Weasel Phlipot
53 Bobby Stremme
57 Josh Malott
62 Randy Shuman
65 Todd Sherman
71 Logan Beckwith III
71b Boomer Houk
76jr Jacob Wilkinson
77 Andy Bishop
81 Steve Shellenberger
82 Darren Wireman
88 Scott Orr
92 John Brammer
x92 Kenny Carmichael Sr
93w Brayden Watson
96 Richard Swan
99t Tyler Loughmiller
117 Kevin Reeve
117x Adrian Roscelli
127 Shane Williamson
188 Aaron Orr
327 Dustin Bruce
463 Daniel Sanchez
j586 Gordon Parsons Jr
757 Bradley Jameson
SPORTSMAN / SUPER STOCKS (40) FULL
H0 Lee Hobbs
0k Shane Kelley
00k Ken Kelley
05B Josh Boller
05J Justin Jeffries
M1 Jeff Methany
2 Bradly Frye
3x Tanner Chastain
4 Scotty Massie
7s Ethan Schnapp
9CJ Jeff Allen
B9 Brian Barber
9D Dylan Burt
9 Craig Markel
9mm Andrew Pollock
10 Randy Brawley
11L Josh Loomis
15 Cole Shoemaker
17 Jarrod Klay
18H Steve Hollars
19m Douglas McCullough
21B Chris Bleikamp
22t Tony Anderson
24 Allen Markel
32M Tommy Duncan
32 Travis Hamilton
33 Mike Fields
45m Wes McClara
45 Ken Small
55k Kolin Schilt
62 Dustin Weber
66 Chip Slagle
69 Nate Murphy
G71 Reece Novak
75c Tucker Chastain
75 Daniel Snyder
84L James Farley
110 Landen Miller
621 Matt Ramer
STREET STOCKS (80) FULL
H0 Lee Hobbs
H02 Austin Hunter
0s Eric Swan
0 Tim Wilber
00 Marty French
00V Mike Vandermark Jr
09 Rob Myers
D1 Cody DeLong
R1 Jim Ransom
1m Max Stetler
1T Troy Taylor
1 Ervin Turner
2p Ryan Willard
4z Zach Zuberbier
5C Megan Cavaness
6p William Peck
7 Dwayne Cigancik
7c Chevy Romans
7B Shawn Valenti
8 Chris Hunter
10 Eric Hunter
12 Kody Conner
14 Megan Erwin
14D Dalton Mannin
15JR Andrew Short
16b Bo Barger
16 Kyle Barger
17d Mike Dexter
19 Ron Wilkes
20x John Rhoads
20 Tanner Sullivan
21k Steve Kidney Jr
21 Dustin Pruitt
22 Bill Bradley
22s Keith Hiller
22f Fred Traxler
23p Sawyer Prosser
26B Andrew Bogart
27 Eric Legner
29 Raigen Rich
30 Peter Hayes
32H Dan Hennig
32 Brice Slavens
33m Estevan Martinez
D33 Chuck Prough
37 Kaleb Hinkley
41N Ryan Nethers
42 Jesse Simmons
44 Josh Frye
44jr Danny Komisarcik Jr
51 Brandon DeLong
51f Jason Fritz
55R Zane Reitz
55 Austin Smith
55Y Richie Yost
57 Joel Herandez
57J Jeffrey Jessup
58 Ty Papkey
64 Don Hopkins
66 Derrick Weiand
67 Carlind Forsythe
K67 Ian Keller
73 Jeff Hinkley
75A Andy Barr
77R Josh Allerding II
77 Bruce Howe
78M Phil Gerlach
78 Patrick Hite
83x Josh Sternberg
83 James Williams
84 Eric Watz
85 Chuck Smith
88 Tom Harrison
91 Larry Long
99k Jerrad Krick
99M Shawn McFeters
114 Austen Hubbard
117 Joshua Smith
1903 Russ Lagneau
1911 Jason Carson
Friday Thunder Car waiting list for Saturday Street Stocks
Ray Smith
Jacob Kolwyck
TJ Larson
Nathan Banister
Jeremy Conley
Chad Neeley
Kevin Green
Travis Larson
Sheldon Oberle
HORNETS (60) FULL
0 Elzie Kipp
00 Mike Currier
08 Cloie Dryer
1 Dino Antonelli
2C Conner Garrison
2m Connor Meacham
3g Ryan Crocker
3x Phillip McCord
3r John Ruby
3 Robbie White
4 Nathan Sumerix
5x Brian Isley
K6 Richard Kimpton
7k Cody Kipp
7j Justin Stahl
8 Anthony Wood
9x Kirby Stevens
9 Aaron Tatman
10 Dustin Lumley
B12 Matthew Balthazor
12 Marq Eaton
13M Matt Minor
13 John Stowers
14k Kaden Williams
15x Paul Steeter Jr
16 Aaron Yates
17 George Meacham
17P Josh Pulsipher
18 Jeremy Wilber
19 Donald Griffin
20 Allen Hite
22 Drew Phillips
22R Shane Reed
22j Joshua Wright
24A Gage Allen
27 Bryan Woodall
37H Kaleb Hinkley
37 Brandon Tichelaar
41 Austin Slone
44 Alex Wilson
45 Reece Riser
46 Cross Reed
54 Casey Elliott
58 Mick Lumley
58P Derrike Prater
64M Ashley Webb
68 Chad Freed
70 Jason McBride Jr
74A Brayton Arthur
75 John Allman
77 Alicia Allman
79 Steve Schuck
88 Estevan Martinez
92 Derek Juhl
99 Dalton Mickle
144 Jeremy Wilson
599 Ryan Schrock
747 Dayton Warren
911 Blake Andrus
7D9 Todd Drewes
Waiting List (in order of received registration)
Bill Hobbs
Cory Gumm
Dominic Morehouse
Maggie Witczak
Tyler Morehouse
Shannon Walp
Jacob Myers
Josh Gamblin
Jamie Razo
Jason Spencer
Frank Reeves
Bambi Lank
Greg Marlow
Anthony Witczak
Brady Hines
Eli Kolodie
Chad Taylor
Evan Eckhoff
Topher Hillman
Justin Groff
Mike Siegel
Zane Yost
Chris Harrington
Scott Harrington
Derrick DeFord
Rick DeFord
Next Race - TBA
Friday Show - Thunder Car entries capped.
Confirmed Entries
410 NON-WING SPRINT CARS (15 SO FAR. A lot More expected this week)
0g Kyle Shipley
01 Anthony D'Alessio
02 Brandon Long
5T AJ Hopkins
5j Joss Moffatt
9z Zack Pretorius
24p Shane (not a nice word)(not a nice word)(not a nice word)(not a nice word)rum
27 Ken Drangmeister
34 Parker Fredrickson
44 David Hair
49 Brian Ruhlman
57 Cole Bodine
77 Braydon Cromwell
86 Keith Sheffer Jr
99 Jack James
MIDGETS (15 Entered so far. A lot more expected this week)
0 Keith Ousley
3 Dave Fetsch
5x Adam Taylor
9p Wes Pinkerton
10 Chett Gehrke
11c Glenn Waterland
18 Alex Nalon
21D Justin (not a nice word)(not a nice word)(not a nice word)(not a nice word)erson
25v Ben Varner
42 Cory Guingrich
43 Ronnie Gardner
46 Russ Gamester
57 TBA
76 Rich Drangmeister
88 Scott Orr
RACESAVER 305 WING SPRINT CARS (22)
00 Michael Helterbran
4T Dylan Troyer
5 Gary Gipson
5L Keith Langley
14c Danny Clark
15J Dustin Stroup
17 Austin Powell
18 Alex Nalon
19 Alfred Galedrige Jr
21x Shane O'Banion
22H Rod Henning
23 John Paynter Jr
23S Bradley Sterrett
23J Jordan Welch
37 Bryce Norris
39 Justin Mathews
50k Kevin Champoux
67 Tyler Miller
78 Justin Clark
81 Alan Brown
83 Carson Dillion
87 Nate Franklin
THUNDER CARS (60 Entries. 56 entered so far) 4 Spots Left
1 Ervin Turner
2 Anthony Hansfiord
3D Jeremy Martin
5H Austin Hunter
5 Chris Hunter
7h Kyle Cook
7x Jon Doughty
7 Jason Shafer
8ball Jacob Wilkinson
9M Landon Metcalf
10s Brandon Shelhart
11b Michael Bennett
14 Brendan Mounce
15 TJ Larson
16H Terry Henderson
16L Dylon Holycross
17 Preston Oberle
18C Calvin Corning
18DK David Hurst
19 Gregg Tarr
21k Jacob Kolwyck
22 Nathan Arterberry
23 Will Hart
23p Sawyer Prosser
24K Spencer Knight II
25 TJ Smith
26 Mike Vandermark Jr
27p Bryce Blevins
27 Mike Reitz
28 Rick Paul
43 Ryan Coley
45 Jeremy Conley
51f Jason Fritz
51 Travis Larson
55 Tyler Holloway
55x Mike Lofgren
55Y Zane Yost
57 Chris Joseph
58 Kevin Green
60 Nathan McDaniel
65 Wally Kerst
66 Steve Nolen
73 Ray Smith
74 Ben Williams
77 Greg Long
78 Clint Bell
87 Nathan Banister
88D Jordan Danford
90 Lee Hall
97 Chad Neeley
99 Justin Griffith
99p Nate Payton
111 Kirby Trent
X225 Trevor Bitterling
416 Jason Fuller
Xrp Sheldon Oberle
Next Race - TBA
Everything was pushed back a day due to weather. It live on Flo right now with Late Models.
What's the big deal 2 thousand to win they should pay that on a regular Saturday night.
3vWide
They don't race late models there weekly. Kokomo is a Non-Wing Sprint Car Track. Besides it's over. If you don't like it don't comment. They get a tone of cars for this show. Brownstown racer Steve Peeden won the late model feature over Rusty Schlenk, & Chad White
Next Race - TBA
Twenty-five straight green flag laps in the late model feature. And in the modified feature, I believe only one caution. That's pretty impressive for both those divisions, for as few times as many of those drivers race at Kokomo.
Late Model race was a awesome show the top two battled for many laps..And modified feature was awesome too..How about a hats off to the O'Connor family for working there buts off too get the Kokomo Klash in with all the rain....Thank you to the whole entire O'Connor family I appreciate everything you do for racing...
Man I don’t understand people that are critical of payouts. Driver and fan attendance are the real determining factors. If race teams and subsequently fan attendance falls off then it’s up to the promoter to adjust or go under. I didn’t attend this event but looks like w good car count and from one description some good racing. IMO, the most erroneous sentiment out there is that you need “big name” drivers to have a good event. Hogwash!
I hate time trials.
