Results 1 to 12 of 12
    Jun 2020
    18
    Default Concave air cleaner top
    What do the concave air cleaner tops like Mcreadie is running do compared to the standard convex top?
    Oct 2017
    1,369
    I haven't seen it but it looks like he runs a 5" filter witch alot of guys don't anymore. If so alot of guys run a flat top for better visibility
    Mar 2018
    Macon GA
    218
    Certainly makes you wonder...... the 39 has arguably the smartest guy in the pits working on his car, and he has by far the biggest and furthest sticking out air filter. No way its for aero reasons.... right??
    Dec 2008
    thedirtysouth
    4,014
    decoy maybe ????????
    Aug 2012
    213
    Gets the incoming air turning downward towards the carb for a better flow pattern with less turbulence inside the air cleaner. No proof just guessing
  6. #6
    That's my guess also. I watched engine masters and they made more hp with a salad bowl on carb directing the airflow down
  7. #7
    Jun 2020
    18
    I see, anyone know where to get one?
  8. #8
    Jun 2007
    571
    Quote Originally Posted by XRNone View Post
    A salad bowl ?
  9. #9
    Oct 2017
    1,369
    Quote Originally Posted by RacerX10 View Post
    A salad bowl ?
    they literally took a big stainless steel salad bowl cut a hole in it and put it on top the carburetor just to demonstrate that anything that could help straighten the air going into the carburetor can help make power
  10. #10
    Feb 2020
    5,876
    Fuel injection is more better
  11. #11
    Jun 2020
    18
    A salad bowl ?
    Sorry for the lack of Specificity... I was meaning the air cleaner housing McCreadie runs.
  12. #12
    Dec 2012
    29
    When you narrow a passage that carries airflow, usually the airflow past the restriction will be at an increased velocity when compared to the air before the restriction. Also, air flows through a gently sloped turn flows much better than it flows through and abrupt 90 degree turn. Remember the 1996-2000(may not be the exact years) gm truck heads that we all call "vortec heads"???? One of the things that makes these heads so special among stock gm heads is the fact that the intake port has a "ski slope shape" at the turn. Most of the heads before these had a very abrupt turn about half way down the intake port. Theese heads also had a uniquely shaped combustion bowl, along with a spark plug placement that differed from earlier heads. These heads make big torque numbers in the midrange, something like 1500-5000 rpm range, and these big numbers are said to be because of the improved air flow that the intake port delivers.
